Suspension Techniques Sway Bars.
  • De //m3
    • 165
    Has anyone heard anything about theses sway bars since they were re-released. I guess they've been revamped to try and counter the problem they had with tearing out mounts. I tried to order a set a while back but they had just been recalled. Just wondering if anyone has the new ones or has heard anything good or bad about them.
    2001 330i - In the garage.
    1986 335is - 325e with Euro 735 M30B34, Under Construction.
    1989 E30 ///M3 - Sold.
    1975 2002 - Sold.
  • reelizmpro
    • 9558
    They have been unavailable for a while now. I wonder if they'll decrease the diameter of the rear bar to 16mm like the other kits, although I think it'll be a bad idea. True the bigger 19mm rear bar tends to rip the mounts but not after you weld in the reinforcements, which is something every competitive driver should do anyway. If they go with a 16mm, it'll solve the problem but at the expense of not being as stiff. Even if they allowed more adjustment on the smaller bar to compensate, it still won't be as stiff as the 19mm bar.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • schnitzer teil-jäger
      • 661
      the spec e30 guys were having a problem with the bar not fitting correctly into the mounts. Looked like they used the same centerline for the 19 bar the the stock14.5 used and the larger diameter interacted with the mounting brackets. The new ones should have a larger center to center bend/
      w
      • bwanac
        • 3354
        where are the welds made? what mounts are ripping out?
        • bimmerphile
          • 3495
          no kidding Barry. When I installed those rear bars, they were a bitch an a half.
          • De //m3
            • 165
            What I was trying to say is that the bars HAVE been re-released and you can get them at shox.com. Sizes are Dia. front-7/8", rear-3/4." Which I believe is just the same as they were before. I was jsut wondeing if anyone knew what had been changed if anything. they may be including a reinforcement kit or something now.
            1975 2002 - Sold.
