The one with the spring or without? Thanks.
Which rear main seal is better?
A main seal can prematurely fail because it is an inferior part, it is installed incorrectly, or the sealing surface on the crank shaft may be grooved. in the last case, seating the seal to other than normal position is cheaper than replacing the crankshaft.The car makes it possible, but the driver makes it happen.
