Oil Service
    Oil Service
    Just did an oil change on my car (318i M10) but the oil service light wont go away. I backed off the oil filter and started the engine to bleed the air out but nothing happened. What am i missing?
    Cheers
    Cheers
    Bahahaha you need a tool to reset it
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
      You don't need a tool...
      Just follow the instruction here
      You can use just a wire or something similar to connect the pins.
        This and put a fuse between the wire just in case you connect the wrong pins.
        COTM
          phewwww, thanks heaps :D
            paper clip
              did you really back off the oil filter? nfw.
              Ma che cazzo state dicendo? :|
                paper clip didnt do anything for me
                this book i have says copper wire will work. i pretty much just ignore mine tho. maybe i had a "fake" paper clip the first and only time i tried
                m20 is plenty. im simply a drifter.
                build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                  Yea, thats what it said the manual.
