Changing the rocker arms without removing the head.
  • Smoove1
    • 505
    I was just wondering if anyone has done this before. I'm going to attempt to slide the rocker shaft out through the front of the car. It looks like it will clear the radiator supports and I can drop the A/C condenser without removing any lines. Obviously the radiator and other things in the way will be removed but I think it is very possible. Anyone's thoughts or suggestions?
  • Jordan
    • 12913
    Its far easier to just pull the head. Dont be scared.
    https://mtechniqueabs.com/
    • Smoove1
      • 505
      I pulled the head last time. I'm just trying to save myself the $180 for a gasket set and $60 for new head bolts.
      • Jordan
        • 12913
        Head gasket is $20, and Headbolts are $30
        Where are you buying your parts?
        • AndrewBird
          The Mad Scientist
          • 11898
          Why do you need new head bolts after you pull the head?
          Andrew
            • 34839
            because they stretch and cannot be retorqued.
            • rwh11385
              lance_entities
              • 18403
              Re: Changing the rocker arms without removing the head.
              Nope. Not gonna happen. I tried.
              The only thing in the way is really the distrubtor, which can be taken off easily and the condensor will be in the way as well.....but that's not the point, the rocker arm shaft will not want to come out. You use a dowel and a mallet to remove them, how can you get either between the firewall and the head.
              Just take off the head. I might do so myself actually. The Haynes manual sucks. :( But my new Bentley spells it out much better :) .
              But kid, don't try it w/o removing the head, you might get the shaft to nudge a bit, but it won't come out all the way. And your BMW deserves to be fixed right. You might as well put in a cam if your ever feel like putting one in, as the head is off anyway. And are those rockers stock, or have they been replaced? Some recommended if one went, the others aren't long behind.
              • Smoove1
                • 505
                I bought the complete gasket set for $180 from Bullet Performance and the head bolts from them also.
                I guess I'll just pull the head off. Are there plugs on the ends of the rocker shafts?
                • rwh11385
                  lance_entities
                  • 18403
                  Yes, there are four rubber plugs at the end of the shafts, but I the head gasket sets I looked at included them.
