Im trying to install my markd chip I just got in the mail. Did anyone else have the problem where their old chip was soldered into the board? Is my only choice now to go out and get a soldering gun to get this bitch out? If I try to pry it out Im afraid Im going to break some leads.
Problems with chip installation
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.Tags: None
Re: Problems with chip installation
Originally posted by madjurgenIm trying to install my markd chip I just got in the mail. Did anyone else have the problem where their old chip was soldered into the board? Is my only choice now to go out and get a soldering gun to get this bitch out? If I try to pry it out Im afraid Im going to break some leads.
James
The early eta 027 ecu's had the chips soldered in. I've seen 2 84's with them soldered. One of my friends unsoldered it and put in the chip. but had problems and ended up buying a new ecu. He wasn't to good at soldering and probally friend the board from to much heat.85 325e 2.7 ITB'd stroker
