Window wont roll down
  • Alecs MacDonald
    • 729
    My passenger side window has been inoperative since I purchesed my car. I have pulled the door cover off and I have power at the connector to the motor. When I press the widow switch all I get is a single "click" from the motor. Is there anything else I can do before I replace the motor? BTW, the car has the early style window regulators. thanks
    '88 325ic
  • Alecs MacDonald
    • 729
    I guess thats a no then. Moving on, who has replaced their early style motors? Difficulty? I guess I need to make a wtb thread............
    '88 325ic
    • Bimmerfanatik
      • May 2004
      • 5349
      Just a click? You should be getting more than a click.
      Replacing the regulator is easy. Two 10mm bolts holding the rear of the window to the track, undo those and tip the window out, then a handful of 10mm's holding the regulator in. Motor comes with the regulator - just gotta finagle the whole thing out. It's a big S - easy to figure out when you're in front of it.
      These regulators go junk real easy - just replace it and see if that helps. They're cheap enough.
      • Digitalwave
        is a poseur
        • 6292
        I just put up a pair of window motor assemblies with regulators on ebay if you are interested.
        RISING EDGE
        • Bimmerfanatik
          • May 2004
          • 5349
          They're the late style TJ - so he'd have to make some modifications to make them work.
          How about a link to that auction though, for someone who wants to do that modification? :)
          • Alecs MacDonald
            • 729
            Is it possible to do the late style modification without the glass? I really hate the way these early style windows arent smooth.
            '88 325ic
            • Bimmerfanatik
              • May 2004
              • 5349
              Nope.
              • Digitalwave
                is a poseur
                • 6292
                Check the fs/wtb my friend.
                RISING EDGE
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  Thanks Teeeeeeeeej.
