Help! My trunk is stuck!
  • PROLAZCO
    • 180
    PLEASE HELP! i closed my trunk today and went to open it and it wont open! IDK WHAT TO DO!!! HELP!!! I HAVE TOOLS IN THERE! HOW DO I OPEN IT !?!? IT IS STUCK! IT COMES UP A LITTLE BIT AND GETS STUCK! I HAVE A 1990 325i cabrio. HELP!
    -Anthony
    Originally posted by whiltebeitel
    Has anyone told you your car sounds like secks? Big, manly, hairy sex, that is. None of that wussy romantic "making love" crap, either.
  • Huff
    • 2488
    So, it will just unlatch a little bit? It sounds like something might be stuck blocking the hinges... Do you have it full of stuff?
    • PROLAZCO
      • 180
      No I just have like a wrench and some wrachets in there so none of that's blocking anything. Any ideas what I could do?!
      • Simon S
        • Oct 2004
        • 3758
        I assume you've already tried using a key in the lock in different ways?
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • zxert
          • Jan 2011
          • 444
          Same problem. I'm gonna have to shred the trunk lock. Basically I can turn the cylinder all I want but its not connected to the lock mechanism.
          Originally posted by StewStewIloveyouyou
          hahahahahahahahahahahahahahahahahah f--- this community its like am making my life with you guys
          And am making my life with you guy too. ;)
          • Huff
            • 2488
            You said it comes up a little bit, so is it unlocking and the latching mechanism letting go? Maybe the hook attached to the trunk is bent.. Does the truck come up enough so you can see it?
            • lennon
              • Jun 2008
              • 1416
              if the trunk is stuck, come through the ski-pass behind the back seat.
              • Ceeker
                • Sep 2009
                • 2821
                umm...the vert has no ski pass. :-)
                See if you can make either an access hole with the vert hatch up and a long extension to remove the two 10mm bolts holding the lock in. If not. Then try from the outside. You can hammer the cylinder out. there is a snap ring holding the key cylinder at the back, in the housing. If this breaks loose you can most likely pull the cylinder out from the front and then you can access the pin which releases the lock. I believe it is to the right of the hole. it is a vert catch which you have to push forward.
                • StereoInstaller1
                  GAS
                  • 22679
                  I can walk you through how to unlock it IF you think the lock motor might still work.
                  I mean, obviously the central locking is not working or you would not be posting this, right? But, there is a chance that the lock motor itself IS working, and if you are willing to take out the central locking relay, you could jump the wires at the relay with a normal 12V battery.
                  I am not making any promises, but there is a good chance the lock actuator (motor) itself still works. This could get you in with zero damage.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • lennon
                    • Jun 2008
                    • 1416
                    they make convertible e30s? that's awful...
                    • Gilroy
                      • Jun 2011
                      • 3
                      All the posts are very nice. I really like and very much impressed by their features.
                      • Ceeker
                        • Sep 2009
                        • 2821
                        This definitely is the first way I would try it!! bravo for the post, and thank you. could you tell us which wires to bridge to jump the trunk lock actuator?
                        • PROLAZCO
                          • 180
                          Firstly,
                          You are a bastard. :hitler:
                          Secondly, i cut a hole where the licence plate goes. i can view the full lock mechanism working... yet nothing happens and it still wont open...
                          • PROLAZCO
                            • 180
                            bump
                            • StereoInstaller1
                              GAS
                              • 22679
                              What to do is actually pretty easy.
                              Pull the central lock relay, the one under the left speaker. Look for the blue and white wires, those run all of the actuators.
                              Jumper from the red and brown (+12V and ground) to the blue and white. If you run them 1 way it will lock, the other way will unlock.
                              MAKE SURE YOU REMOVE THE MODULE FIRST!
                              Yes, it really is that simple.
                              Closing SOON!
