How fast do fluids dry out?
  • BrooklynMW
    • 1263
    I left my car for a week while I went on vacation. It was parked in a covered spot out of the sun. When I picked it up last night, the steering was crying a screaming and the brakes were pretty dry as well. My only educated guess is that the brake and steering fluids either dried up or completely leaked out. There were no puddles underneath the car, though they could have evaporated.
    Does this sound normal? One week no driving, and the steering pump is empty? I turned the wheel back and forth a bunch to try to get the juices flowing, and that helped a bit, but didn't completely solve the problem.
    Also, I had the power steering lines replaced 2 months ago when I did the rack.
    Thanks in advance.
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
  • drumad
    • Aug 2009
    • 1700
    so.. I'll just go ahead and ask.
    Did you actually check your p/s and brake resevoirs?
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • BrooklynMW
      • 1263
      No it was late at night. Didn't bother to check before I started car (never thought to). when I got home it was too dark. I plan on checking today.
      current:
      • BrooklynMW
        • 1263
        Originally posted by M-technik-3
        Then why ask this question?
        Because I'm sitting in front of my computer.
        current:
          • 34847
          brake fluid and ATF don't evaporate that easily
            The fluids didn't evaporate. If either is low, there is a leak.
            The brakes may have felt scratchy from rust that formed on the rotors while the car sat.
            • BrooklynMW
              • 1263
              Well, I'm going to go down and check the reservoirs, also the power steering lines. Also will check for rust on the rotors, but don't see how they would rust so quickly.
              current:
              • drumad
                • Aug 2009
                • 1700
                he's going to come back and say there wasnt any rust on the rotors
                2008 335i - n54b30
                1991 318i - m52b28
                • BrooklynMW
                  • 1263
                  Yes you're absolutely right. Rotors looked pretty good. I think the pads might be a little dried out. Saltwater in the air and all.
                  Sho' nuff, the power steering fluid reservoir was nearly empty. Which means I have either a new leaks, or the old leak never got fixed. Filled it back up and wheel turns normally now.
                  current:
                    Of course the rotors look good now. The pads will have scrubbed the rust off.
                    • BrooklynMW
                      • 1263
                      ahh. I knew that
                      current:
                      • drumad
                        • Aug 2009
                        • 1700
                        ahh. I knew that
                        Anywho, seems as if your problems are fixed. Just make sure to check your p/s resevoir as soon as you can and make sure that any significant amount of air did not get in your lines. Otherwise, bleed it and check for leaks.
                        2008 335i - n54b30
                        1991 318i - m52b28
                        • bloodshot-e30
                          • 1494
                          lol it takes about 10 seconds for rust to form on rotors if they get wet.
                          ^Back in the game^
                          BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                          FS thread:
                          http://www.r3vlimited.com/board/showthread.php?t=214105
                          • june3o
                            • Apr 2011
                            • 90
                            when fluids leak and dries out, it will create a stain.. especially oils..
                            • BrooklynMW
                              • 1263
                              Every kind of line possible could use a good bleed.
                              Can't check for stains. The previous proprietor of my parking space drove a W112 diesel converted for vegetable oil. So there's all kinds of good floor artwork at my spot already.
                              current:
