bouncing idle, m10
  • taiden
    • Oct 2009
    • 178
    bouncing idle, m10
    Hey all,
    I have a 1985 318i and the idle bounces over and over again from about 800 rpm to 1200 rpm. rrrRRRaa-rrrRRRaa-rrrRRRaa-rrrRRRaa
    It's absolutely infuriating.
    I tried swapping out the AFM and no luck. But I have no idea what the condition of the used AFM is.
  • AndrewBird
    The Mad Scientist
    • 11898
    Sounds like you need an new idle control valve.
    • Holland
      • Nov 2008
      • 7212
      ^ and that is exactly why I don't fix mine. I have the same issue but only when I switch the A/C on, so I'm not really bothered to fix it seeing the price of a new ICV is through the roof.
      Originally posted by DEV0 E30
      • taiden
        • Oct 2009
        • 178
        Time to put a v8 in it I guess
        • AndrewBird
          The Mad Scientist
          • 11898
          You might try cleaning it first. Pull it out and spray it down with carb cleaner. Sometimes they are just dirty.
          • lennon
            • Jun 2008
            • 1416
            smoke test and report back
            edit:... when all leaks are repaired.
            • taiden
              • Oct 2009
              • 178
              Just FYI for everyone. I have already sorted out the vac leaks and already cleaned the ICV... come on now, give me a little more credit than that. ;)
              As it turns out, this issue was solved by unplugging the idle speed relay and plugging it back in. I suppose there was enough corrosion to cause issues.
              Idle is now steady but it is high. I am just about to set the ICV using a multimeter as outlined in the bentley manual.
              Thanks all for the help :)
              • taiden
                • Oct 2009
                • 178
                Alright so idle is now steady, but it is high. I set throttle body clearance to 0.0015" and adjusted the ICV to it's lowest speed, and it is still too high. Penny trick it?
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  The "penny trick" will confirm you have an ICV issue but it will only be effective in 1 situation (presumably at operating temp on an "avg" day) so at best its temporary and good for diagnosis. Try removing your ICV and put a wine cork in each connecting hose. If your engine only runs with a little throttle, then you know its your ICV...and if you do the penny thing dont let it get sucked in to your engine :-)
                  Alice the Time Capsule
