Blown Head Gasket, right?
  • SickE30
    • 769
    Okay, oil on top of valve cover, choppy idle, blue smoke, no power....Blow HG, right? Should have changed it eh? :oops:
  • 808BMW
    • 2910
    Is your oil milky? I always thought the exhaust smoke was white or grey or something.
      • 34844
      it depends on where your gasket blows, and if it breaks through an oil or water passage.
      • rs4pro3
        • 5808
        Run a compression check to varify. If one cylinder is 15-20psi lower in pressure the the other cylinders then most likely the gasket is bloww on that cylinder.
        85 325e 2.7 ITB'd stroker
        • modifiede30
          • 1208
          Don't want to scare you, but it could also be the head itself.
          Driving is the only way to go faster....
          • rs4pro3
            • 5808
            Yep that it could, If you do pull the head take it to a machine shop to be tested and resurfaced if needed.
            • SickE30
              • 769
              Just drove it to my shop, not messing with this job. It put out smoke for about a minute and ideled choppy for 2/10th's of a mile rouhgly then it was silky smooth it was in the power band. I was satisified. My hopes are high that it is something minor. As I am not finished with my new motor and I am not putting it in half ass. It will be bullet proof. Thankyou for all of your advice guys, as always it is highly appreciated. :D
