Steering wheel compatiblity
  • Digitalwave
    is a poseur
    • 6292
    Alright, my car came with an airbag from the factory. Back in the day I tried to replace it with a MINT M-tech I wheel that I got on eBay. It didn't fit the splines correctly, and wouldn't slide all the way onto the steering column. I tried fitting a 3 spoke sport wheel from a 325eS, and it fit fine. I have no idea why the M-tech I didn't fit, unless it was from an E28. It had E30 stamped under the roundel though.
    If the 325eS wheel fits my car, theoretically, an M-tech I should work right? Aren't the splines on all E30's the same?
    RISING EDGE
  • AdamF 88iS
    • 2051
    Um, the ES wheel should be an M tech 1, same as the IS and the M3 wheel.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Digitalwave
      is a poseur
      • 6292
      It's not. It's from an 84 325e fully loaded, I forgot they weren't 325eS's. It's the same as the cabrio wheel.
      Do you think an M-tech I will fit my car, Mr. Fogg?
      RISING EDGE
      • Erick
        Official R3V Drifter
        • 11169
        I'll bring my Mtech1 with me to the meet and if we stop by your house on Friday we'll swap them out to see if it fits.
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
          • 37829
          All E30 wheels are interchangable, you'll just need a spacer when putting a on airbag wheel on a original airbag car. My car is a 91 and came with an airbag. I have had a MTech-1 on it, a 3 spoke sport wheel, and a Momo.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • PeaveyBassist
            • Sep 2004
            • 3511
            Spacer = washers right? Or is there a better solution?
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • AdamF 88iS
              • 2051
              Yes, it should, Mr. Lathrop.
              Adam Fogg- '88 M3
              • nickmp0wer
                • 1427
                how hard would it be to just swap the colum with a non airbag one?
                • rs4pro3
                  • 5808
                  Easy,if there wasn't those stupid shear bolts to do with.
                  85 325e 2.7 ITB'd stroker
                  • Digitalwave
                    is a poseur
                    • 6292
                    Hopefully I will already have a wheel in my posession by then. Matt, I already have a spacer for using this 3 spoke wheel.
                    Thanks for all the help guys.
                    RISING EDGE
                      • 37829
                      Ya I would guess that MTech 1 you tired was somehow a different fitment wheel or had fucked u0p splines or something because it obviously "should" have fit.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • Digitalwave
                        is a poseur
                        • 6292
                        Alright, riddle me this. I went over to Robbie's today becaus he has an M-tech I wheel in his daily driver, so we tested it in my car. The same thing happened as last time. The splines line up, and the wheel slides on, but not as far as my 3 spoke, or even his Momo wheel do. The difference is only about 1/4-1/2", but its enough that the wheel doesn't lock and the turn signal doesn't return.
                        Since the splines line up, the only possible thing we could think of is that the splines taper down and they don't let it slide on all the ways. I looked at the steering column on his 84 318i, and it almost looked like it tapers some, if not the ends round out a little.
                        Usually, when I slide my wheel on, you can see some splines exposed, and thats why I have to run the extra spacer before the washer/nut, so there is no play in the wheel. With the M-tech I, the wheel stops at the end of the splines and won't go any farther. If I push it hard, it gets stuck, so it seems like its tapered to me.
                        Would it be alright if I did a little dremel'ing to the end of the splines, enough to wear the taper down and get the wheel all the way on? I am sure there are enough splines to do that and still have enough to secure the wheel safetly.
                        Wow, that was a long post.
                        RISING EDGE
                          • 37829
                          I really don't know why it's not fitting on your car TJ, I find that really odd. There shouldn't be any difference between the splines of the MTech 1, sport wheel, or stock 4 spoke [non airbag] wheel. As said, I had a MTech 1 wheel on my car with no problems.
                          \Sorry I have no help to offer, good luck with it.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • nickmp0wer
                            • 1427
                            the e30 is different
                            • Digitalwave
                              is a poseur
                              • 6292
                              Well, I installed the M-tech I wheel that I bought today and it fit fine. I have no freaking clue why some fit my car and some don't.
                              RISING EDGE
