launched my 318i, now it doesn't run
  • taiden
    • Oct 2009
    • 178
    Alright, sooooo yeah. It's raining here in beautiful Maine, and I decided whilst at a stand still to launch my 318i. Rev to about 4.5k and ceremoniously dump the clutch (but not in a side-stepping fashion, slightly more gentle).
    The car bogged down and proceeded to run like ass.
    At first I was sure that it was my AFM stuck wide open, as was previously the issue. At first it was running, but would hardly operate under load. After checking a few things, the car won't even run now. It just sputters randomly.
    The things that I checked:
    vacuum lines
    AFM
    all visible EFI related plugs
    checked for loose plug wires
    checked for damaged cap/rotor
    cleared the engine to check for flooding
    The car is currently on the side of the road somewhere and I will be returning to it to try some other things. Any ideas would be appreciated.
  • accident
    • 7303
    I had this happen once in a 325is. Turned out the intake boot had come off the throttle body, but only on the bottom so visibly it looked still attached.
    Moral of this story?
    • taiden
      • Oct 2009
      • 178
      I ended up finding it:
      Pretty funny, had excellent spark at all four plugs, swapped in a spare AFM, car still didn't run, but it was backfiring sporadically.
      Pulled the cap off, and turned the rotor. Uhmmm. I don't think rotors are supposed to turn 360* when the crank isn't moving.
      $7.60 later at a NAPA that was a 1/4 mile away and I was on the road again.
      The culprit:
      • jeffnhiscars
        • Jun 2011
        • 6011
        You spun a rotor ? There's a first for everything !!
        Beats spinning a bearing :-)
        Alice the Time Capsule
