153 to 173 ECU
  • 325ix
    • Aug 2009
    • 7783
    153 to 173 ECU
    A few days ago I was getting a CEL after idling for about 20 secs. It would come on and stay on for a few restarts afterwards. I decided to put in the 173 ECU I have. It fixed the CEL, it no longer comes on. However, I now get an anti-lock brake light on the dash. Any ideas? This is in an 88ix.
    The DME has nothing to do with the ABS, that fault is a coincidental failure.
    While the original DME could have been faulty, the CEL while idling is more likely to be a Lambda fault and caused by an aged O2 sensor and intake leaks. The useful life of an O2 sensor is 100k and it is a scheduled maintainance item. A smoke test is the only sure way to locate intake leaks at any of the possible locations.
      • 37833
      I am SO TIRED of seeing a smoke test suggested.
      Grover Beach, California
      BimmerHeads.com
      • b*saint
        • 3794
        jlevie is right tho. These cars are so old and crusty you can't rule out intake leaks.
        Ma che cazzo state dicendo? :|
        • QUKBMER
          • 8178
          Use carb spray like the old days. Smoke testing is for late model 2000-up models.
            • 34844
            what? :weak:
              • 34844
              actually, the ABS issue does have to do with the ECU (it's an ix thing).
              you need to add a 1k resistor from pin 17 of the C101 connector, to ground.
              • 325ix
                • Aug 2009
                • 7783
                Ok, thanks, I am going to say that since I don't get a CEL anymore, it was my Ecu that was bad. It went away. Thanks Nando.
                  • 34844
                  it could come back. it was in an old TSB on early ix's - what happens is the output from the ABS computer to the ECU can end up floating. Grounding it with a resistor still lets it work but you won't get the ABS fault anymore.
                  • 325ix
                    • Aug 2009
                    • 7783
                    If it does, then I will look into it, but for now it is gone. I think my tps may be going bad, because it only does it on idle. Thanks for the info.
                    • b*saint
                      • 3794
                      Wouldnt the carb spray NOT work because your ICV is constantly modulating idle air? Ive never had the carb cleaner trick work on a car with a ICV.
                        • 34844
                        I don't know if the ICV is the reason, but i've never had the carb cleaner trick work on an M20 either.
                        • 325ix
                          • Aug 2009
                          • 7783
                          It works after the icv. I think it may be the reason.
                          • BrooklynMW
                            • 1263
                            I had the opposite problem. I took out my 153 and installed a 173 w/ Bavauto chip. CEL went on after about 200 miles, and my mpg's dropped a few numbers. Put the 153 back in and car ran fine w/o any warning lights.
                            '87 325i "Chewey" (RIP, my beloved)
                            current:
                            '01 e46 325iT "Dot" - #datwagonlife
                            '87 e30 325i "Tui" - she has her mother's eyes
                            • 325ix
                              • Aug 2009
                              • 7783
                              Weird, I think my ecu was the problem, but time will tell.
