How to break axle nut loose?
  • blacksport325
    • 231
    I've tried my impact wrench, PB blaster, and a 30MM impact to 1/2in breaker bar with a total of about 2-3 feet of cheater pipe and its still not coming off, when I tried to put force on the breaker bar the socket leans a bit and flies off the nut, I don't want to round this nut off, however I do have an extra nut just incase I need to get it off somehow. Any other idea's how to get this thing off or keep the socket steady on the nut?
  • blacksport325
    • 231
    Also, the wheel bearing kit I ordered came with a 12 sided axle nut where my ones now are only the regular 6 sides...will this be an issue?
    • bzboardz
      • 1096
      did you take the retaining clip off?
      • blacksport325
        • 231
        Didn't even think about that, let me try..thanks for the quick help.:oops:
        • blacksport325
          • 231
          Thanks man! Came off super easy! I'll probably be back in here if I have more issues
          • netcsk
            • Apr 2004
            • 1609
            Funny how well those lock clips work huh?
            • AndrewBird
              The Mad Scientist
              • 11897
              On a related note, how do you get those lock rings out of there? When Josh and I did his, it would not come out due to a bit of rust and there was no way to grab onto it to pull it out.
              • blacksport325
                • 231
                If you mean the lock plates for the axle nut I just squeezed a flathead screwdriver between the hub and lock plate and hammered it around the perimeter of it until it was bent enough that it would move, then pry it out with the screwdriver. The circlips that hold the bearing in are supposed to be taken out with a pair of circlip pliers...
                New issue, I cant get the axle out of the hub, I rented a slide hammer from advance but it doesn't seem to work correctly or i'm missing some pieces, anyway to do this without a slide hammer?
                • blacksport325
                  • 231
                  fml, slide hammer worked great to get the axle out but now its slide itself back onto the diff when I was hitting it, now im stuck with it half in the hub and half on the diff, i'm not sure how i'll get this out, heh.
                  • blacksport325
                    • 231
                    Ignore the above, patience is key with this, got the axle out, this bearing is definitely shot.
                    • b*saint
                      • 3794
                      I use a 3/8 and 1/2" impact guns, long extensions, 30mm high quality deep socket, and an air hammer with punch bit to remove the axles. I can get an axle out and in 10 - 15 mins.
                      Ma che cazzo state dicendo? :|
                      • blacksport325
                        • 231
                        Impressive, now that I know what I know I could get an axle out in under an hour most likely without air tools.
                        • b*saint
                          • 3794
                          Yea the best way to remove or install the flange bolts is to have the car in neutral without the ebrake on, and use an impact gun (with an extension so the gun is outside the wheel well) on the top bolt, rotating the disc so the next bolt is to 12 oclock. I put a little grease on the socket so it doesn't damage the boot. And it really helps to have locking extensions.
                          The air hammer is so you can hold onto the axle as you drive it out.
                          • blacksport325
                            • 231
                            Back at it now, any tips on removing the drive flange/hub from the trailing arm? it says to hammer a socket smaller than the bearing, i've been hitting it for 10 minutes and it hasn't budged, I dont want to use heat unless I have to..any other options?
                            • b*saint
                              • 3794
                              Yea you want to use a socket and an extension. Hit the back of the extension. I don't remember what size I used. Once you get it cracked free it bangs out fairly easy. I wrote the size I used in my bearing tool kit for future use.
                              If it doesn't work and you use a air hammer, be very careful not to peen over the hub (so use a backer plate or something)
