Hm,now thats a tricky Q (temp guage related)!
  • a3ternus
    • 643
    Well,i own the car (1985 E30 318i M10 4-gear manual) for two years now...
    The temp gauge after some minutes of driving was always standing at the first mark above blue (cold),climbing ocassionally to the half mark,then after a min of two,going back at the first mark (1/3rd) again.
    After a year or so,its behavour changed a bit.Now,after a proper warm up the needle goes straight to the half mark,staying there most of the time,sometimes even climbing a bit (half way between the 2nd and third mark) and then going back to half!
    What could cause this strange change on the reading?!? :roll:
    The radiator fan is working right (i ve done the newspaper trick when at its high speed and it doesnt stop of even slow down a bit...) yet the 'idle' position is now always at the half mark (when the car is warmed up)!
    I m open to suggestions... :?:
    N.
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
  • AdamF 88iS
    • 2051
    There is a brass nut on teh back of the gauge. Make sure it's tight. If it's loose you will get a poor connection and inaccurate readings.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • rs4pro3
      • 5808
      1/2 way is where the guage should shit, not a little above 1/4, As long as it dosn't constantly raise above 1/2 you are fine.
      85 325e 2.7 ITB'd stroker
      • a3ternus
        • 643
        It is well documented on various forums that half of our cars' temp guages sit (when the cars are warm) at the 1/3 mark and the other half s at the 1/2 mark...so,I cant be sure... :?
        N.
        • PanamaE30
          • Oct 2004
          • 768
          Your guage shits?
          :P
          sorry, just noticed it and I'm at work, needed a laugh.
          1988 325iC - "Betty" - Daily Driver/Project Car.
          1993 318i - "The Golden Dream" - Dad's Car.
          1995 318ti - "Hellrot" - R.I.P.
          • a3ternus
            • 643
            :D hahahahha indeed,mine shits alright!
            N.
            • AdironRider
              • Dec 2004
              • 3491
              My car usually sits inbetween 1/4 and 1/2, depending on whether Im sitting at a light, or cruising. Sound like maybe you thermostat is getting a little tired perhaps, as my car when it needed to be changed upped its normal operating temperature. Coolant flush might help as well
              Back to my roots
              • Digitalwave
                is a poseur
                • 6300
                It depends on what degree thermostat you have. My car is usually just above the 1/4 mark when on the highway and such, and gets to just below 1/2 in heavy traffic.
                RISING EDGE
                • a3ternus
                  • 643
                  Yes,maybe you re right,cos up to now it had the same typical behavour...
                  @1/3 when cruising
                  @1/2 when in traffic and back @q/3 again later...
                  N.
