new valve cover gasket
  • CW325
    • Jul 2011
    • 1434
    Im new here and im new to e30's. i just got myself a 325es. i already changed the timing belt, water pump, and put a bunch of new hoses in, next is the valve cover gasket. Any tips to someone new to this?? thanks!:D
  • clydesdale
    • 631
    There are 4 plugs, 2 at each end of the cylinder head. You should replace these when you do the valve cover gasket. There is a pattern to tighten the bolts down. Other than that, it is way easier than everything else you have already done.
    • CW325
      • Jul 2011
      • 1434
      ok thanks it seems simple from what ive been reading, ill definitely look into the cylinder head plugs, is there a proper name for them?
        • 37832
        Rocker shaft plugs is the official name I believe.
        You should also do a valve adjustment at the same time.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • CW325
          • Jul 2011
          • 1434
          does anyone have any good links for a valve adjustment,ive never done anything like it before
          • SkiFree
            • Jun 2011
            • 2766
            ADAMS Autosport
            • CW325
              • Jul 2011
              • 1434
              cool thanks for the pdf! i also found an article on pelican parts that explained it a little easier
