Dinan Chip Question
    Dinan Chip Question
    I have a BOSCH ecu ending in 525 .. & I have a Dinan chip for the 173 ECU .
    But I've been told by MarkD that his chip for the 173 will work for the 525 ecu , is there a difference between the two ecus ? will the 173 dinan chip work with my 525 ecu ?
    Cheers ,
    Robert
    Put it in and try?
      Originally posted by NitroRustlerDriver View Post
      Put it in and try?
      What will happen if it's not supposed to be in that ECU ? :o
        Yes it will work, I have a 173 chip in a 524, All I have to do to get it started is disconnect the crank position sensor for 10 seconds with the ignition on, then plug it in and hold the AFM wide open while starting it and pumping the throttle and sometimes using starting fluid.
        kidding, it works.
          my turner chip was manual specific.
          1989 LN106 Hilux / 3.0TD SFA
          1974 2002tii / stock
          2002 IS300 / 5spd LSD
            I am using a manual chip in an automatic car.
            The dropdown menu to specify trans. type on Turner's site is for newer cars with electronically controlled automatic transmissions.
            The ZF 4HP-22 that US E30's got is all mechanical.
            There was an electronically controlled version for the European market.
              any other inputs before i install it ?
                Don't do it..unless you get correct confirmation you can
                "Hard Work Pays Off"
                1991-bmw 325i (R3vvd)
                1990- 325 (mpowa)(GC)(track)(beast)
                1988- 528e (daily driven when track car broken)
                  I'm waiting to install it . gotta see if its the right one
                    kidding, it works.
                    You sir are heeeeelarious!
                      it will work fine.
