I have an 85 325e, and occasionally (once a month) it won't start, also it idles rough, but has no power problems.
For some reason when I wiggle the reference sensor wires around, it will fire right up.
There is no visable damage to any of the wiring, and they were both replaced about 6,000 miles ago.
I went to check resistance according to my haynes (I know I need a bentley) and they tested bad, both of them. The manual says resistance between terminals 1 and 2 should be between 860 and 1060 ohms, and 100k ohms between terminals 3 and 1, or 3 and 2.
I am getting 1090 ohms between 1 and 2, and the resistance between the others is out of limits. No continuity.
It seems weird that the car still runs, and drives fine without power problems, don't you think? Would these bad sensors cause my symptoms?
Can anyone take a look in their manual and confirm the specs I have listed above?
Thanks
Thanks
