loss of power
  • TG Goose
    • Jul 2011
    • 234
    loss of power
    1984 m10 powered 318i
    I had a fuel pump take a shit, so i replaced it with a brand new working one. Now it has trouble idleing while cold, keeps wanting to stall. It has great power until about 4k rpm, but anything over does nothing. IE you can rev to 5-6k rpm, but the car goes no where. (pulls hard to 4k, then falls flat on its face even tho the engine keeps revving).
    I also replaced the pressure regulator on the fuel rail at the same time, and the fuel pump relay if that makes a difference.
    ______________________________________
    1984 LSB 318i - Sold
    1986 325i - Motor Swapped Track Car Project
    1995 318ti - Sold
    1999 540iA - Daily Driver
  • Sagaris
    • Sep 2009
    • 2243
    How can an M10 lose any m.... nevermind :D
    I would look into replacing the fuel filter. A clogged filter could have strained and killed the old pump and is still restricting flow with the new one. It doesn't explain the bad idle though. Another possibility is a clogged cat.
    • TG Goose
      • Jul 2011
      • 234
      no cat, brand new filter. Maybe I just need to drive it around for a bit to work out any kinks.
      1995 318ti - Sold
      • TG Goose
        • Jul 2011
        • 234
        i figured out the idle problem. I didnt think i needed it, but there is a dampener right after the high pressure pump. without that installed, it would not idle cold, putting it back fixed that problem.
        if i had the wrong coding plug would that keep my car from making rpm's, ie rev limit it? I just did a cluster swap and now i cannot rev it past 5k rpm. I guess i'm doing another cluster swap to see if it fixes the problem....lol
        1995 318ti - Sold
        • Eecen
          • Jun 2010
          • 1235
          Keep in mind this is an M10 you're talking about...
          I am pretty confident that Jetronic doesn't use your tach for anything. I am also quite sure that the wrong coding plug would just make your tach read wrong.
          • TG Goose
            • Jul 2011
            • 234
            i know its an M10, but after doing the fuel pump and cluster swap, its like half the motor it used to be.
            1995 318ti - Sold
            • e30trooper
              • 11576
              maybe 325i cluster ina 318i?
              • TG Goose
                • Jul 2011
                • 234
                I put in my old FPR and it solved my drive ability issues.
                I should have listened to my own mantra, If it ain't broke, dont fix it!. I should have just replaced the broken pump and left everything else!
                1995 318ti - Sold
