I read on a Pelican Parts how to that if you put in coolant and didn't use distilled water that it ran the change of doing something to the sulfides (or something like that) that effectively made your coolant turn into a gel like substance and green.
Now I don't buy it turning whatever was in there green, as I am sure the PO probably put green coolant in, but I do now have the problem of having blue coolant on hand when green was used before.
I was also told not to mix colors. Does anyone know if I have to flush out my system more thoroughly and how to do it?
Also read that my car (325e) takes about 11 liters (11.6 quarts) (which should be a 50/50 mixture of distilled water and coolant). Is this accurate? If so 1 gallon that I bought (3.8 liters) isn't enough to top off the system is it?
