i've swapped in 3 different clusters. 2 i clusters (a moto and a vdo) and an eta cluster (moto) and the tach will always work. but the speedo does not.
when i first got the car, just the tach would work. then, the speedo would work or the tach, but very rarely both. i pulled the cluster and replaced it (retaining the original speedo) and then everything worked great for 2 weeks. then the speedo stopped working. over the next 2 days it would occasionally work if i hit a bump or smacked the dash.
now it does not work at all.
how can i test (with a multimeter) if the speedo itself is bad. if the si battery were bad, the tach wouldnt work either, right? so... after 3 speedos im starting to think the problem is not in the cluster....
