how to set aux fan high???
  • immajackuup
    • Dec 2010
    • 1132
    is there a way to set aux fan high when using a/c????
  • KenC
    King of Kegstands
    • 14396
    It's always on high when a/c is on.
    Originally posted by Gruelius
    • achtunge30
      • Apr 2006
      • 1029
      Interesting - I thought a/c on = low speed aux fan
      good to know!
      - Frank
      '87 325ic M-Tech 1 For Sale!
      http://r3vlimited.com/board/showthread.php?t=407503
      Build Thread http://www.r3vlimited.com/board/showthread.php?t=229347
      • immajackuup
        • Dec 2010
        • 1132
        really? I'm for sure is low because when my temp gauge needle go over half mark the high would kick on.
        • bmwm42
          • 6300
          Not true when you turn on the ac it turns it on low it will only come on high if it reaches the temp setting or you jump the wiring
          Originally posted by bmwm42
          PNW vulture pm me for parts
          Strategic nw e30 command
          • immajackuup
            • Dec 2010
            • 1132
            in which i want it to be high instead of low. damn a/c high is at 400 :{
            • KenC
              King of Kegstands
              • 14396
              Hmmm. I guess I was misinformed.
              I have my electric puller come on when the a/c kicks on too. You can feel the vacuum through the front grille.
              • immajackuup
                • Dec 2010
                • 1132
                got it fix by putting clutch fan back on :}
                • scottinAZ
                  • Dec 2009
                  • 1312
                  best way to get the fan on high speed full time is to jump out the fan at the resistor (connect all wires on the resistor to one side, effectively just using the resistor as a junction block, and then replacing the low speed fuse with a 30 amp one (same as the high speed relay)
                  I saved 15% on my Bimmer parts by switching to ...
                  • immajackuup
                    • Dec 2010
                    • 1132
                    I was thinking the same thing.
                    • Disco Benny
                      • Aug 2011
                      • 123
                      what abotu replacing the high speed switch to a lower temp?
                      My needle jumps between 1/2 to 3/4 while city driving yet at idle it will calm back down to 1/2...I never hear my high speed fan on although the normal speed works as intended
                      NOTE: I already tested my fan with the key ON...it works, just never comes on
                      NOTE: I also have to keep hitting my cluster to make sure where my needle is bc is starts being wacky with the temp rising and my idle jumps to 1500-2000
                      NOTE: Replaced temp gauge switch and Coolant Temp Sensor...
                      Maybe the Temp Switch (2 prong guy) needs to be replaced?
                      • immajackuup
                        • Dec 2010
                        • 1132
                        all i did is cut resistor off then rewire back,change fuse 15amp to 30amp and now is running high at all time at low/high temp. Also using e36 lower temp.
                        • g.ruff561
                          • 1266
                          ^^^^^^^ This................I live in Florida and it works great. R134 ice cold.
                          • rcfanatic
                            • 490
                            What do you mean using e36 lower temp?
                              • 34839
                              E36 M42 thermoswitch, turns on at 80/88c instead of 90/99c (low/high). normally you wire it so the low temp activates the high speed setting.
