parallel condenser
  • immajackuup
    • Dec 2010
    • 1132
    #31
    Originally posted by redsubdivisions
    Tomorrow I will be ordering the condenser from supremecondensers.com and in about a week or so, I will tackle this and try and get a writeup started.
    good luck with the phone attendant from supremecondenser lol
    • redsubdivisions
      • Feb 2011
      • 1762
      #32
      Oh my god, no kidding. I tried to talk to her today and I could barely get a legible English word from her. haha.
      1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
      2012 Passat TDI - DD Duty
      2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
      • immajackuup
        • Dec 2010
        • 1132
        #33
        lol^took me a long time to get the order right and she still mess it up. I need to call her tomorrow so she can resend me a new conformation order with correct information.:crazy::crazy::crazy::crazy:
        • chucker
          • Jan 2009
          • 106
          #34
          Oh man, 2 weeks ago when I ordered this thing it was a nightmare, she is dumber than a damn goat. i did have to extend the tabs on top 1/2 longer. I drilled out the pop rivets and bent new tabs and redrilled and used stainless screws with locks. Just measure your old one and you will see what I mean. I had to cut my rubber grommets loose from my old condenser and I super-glued them back together on the new condenser. The fan then fit fine, Everything else fine, they got the correct line fittings, etc.
          Just be careful of that phone attendant. chucker
          89 M3 "Ms. Bavaria" Garage Queen Cinnabar w/ black guts
          12 Chevy Avalanche "OJ" Black on Black and.... Loaded
          • redsubdivisions
            • Feb 2011
            • 1762
            #35
            Chucker: You aren't kidding. it took me 30 minutes to order this condenser because I literally had to spell and number everything out to her. I really hope it comes in as described. I had to double check everything before I gave it the go ahead to order. Let's hope this is worth the money. I should see this in about 2 weeks (7-10 business days for shipping, apparently), so if anyone is watching this thread and waiting for my write up on it, I suggest coming back in 2-3 weeks.
            • immajackuup
              • Dec 2010
              • 1132
              #36
              Mine is coming in next week Tuesday:p
              • clydesdale
                • 631
                #37
                Outside temp was 82 and pure sun today and it was blowing 42 degree air at 45 miles per hour. I turn the vent speed down to 2. I found out that my condenser from ackits was shipped from americancondensers. It was a direct fit, for the most part. I had to bend the fitting just a bit to get the hoses to line up ok. Even with that, I had to put some rubber inbetween the lines so that they would not rub. I also hooked up and "L" bracket and changed the location of the clamp on the hose from the compresser to the condenser. I am happy with the PF condenser. I am not quite sure what the idle temps are yet, I will check that over the weekend, but the around town temps are fine and for a drop in condenser, I am happy.
                • immajackuup
                  • Dec 2010
                  • 1132
                  #38
                  just got this baby in.
                  • chucker
                    • Jan 2009
                    • 106
                    #39
                    Imajackup, are your tabs too short? Chucker
                    • immajackuup
                      • Dec 2010
                      • 1132
                      #40
                      don't know,what's the measurement??
                      • chucker
                        • Jan 2009
                        • 106
                        #41
                        Imajackup, IDK my car is back together, just measure your old one. Chucker
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          #42
                          I don't know if this will help , but friend of mine who was a factory tech at the dealer back in the e30 days told me to slightly under charge the system when you use r134 so it will blow cold . i think it maybe have to do with the head pressures , iirc.
                          • immajackuup
                            • Dec 2010
                            • 1132
                            #43
                            • redsubdivisions
                              • Feb 2011
                              • 1762
                              #44
                              Immajackuup, I just got mine in this morning. Looks identical to yours. Are you going to beat me to the punch and install it before I do? I am going to throw mine in sometime this weekend if I get some time and take pics and whatnot. Lemme know if you run into any issues or not.
                              • immajackuup
                                • Dec 2010
                                • 1132
                                #45
                                no:D,is too hot to be wrenching in this texas heat. Couple weeks ago I develop heat stroke while changing brake pads on a 350z.:(
