Common Power Steering Leaks?
  • DarkWing6
    • Apr 2004
    • 7144
    On my way home from the picnic my power steering quit working. When I got home I checked the fluid and it was basically empty. Bought some fluid and filled it up. Drove a bit and checked it and topped it off. About 2-3 days later it was all gone again. I haven't had time to check for leaks anywhere so I was just wondering where, if any, are the common places to find leaks? All I can say for now is God bless power steering.
    Thanks
    Derek
  • AdamF 88iS
    • 2051
    Sounds like your rack has let go. Hoese don't usually leak that quickly unless the high pressure line has burst, but I strongly doubt that.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      • 34839
      if it leaks that bad, then it's most likely your rack. you could try using stop leak to limp you around until you can get a new one.
      • Jon '92 325ic
        • 172
        A newly rebuilt power steering rack...
        A newly rebuilt power steering rack... goes for $250 - $275. e30s use transmission fluid and not power steering fluid.
        I'd try filling your power steering with a compatible (chack owner's manual) transmission fluid that has a Stop Leak additive. I've used Valvoline's Auto transmission fluid with Stop Leak in the past and the leaking stopped. This is a good temporary fix to give you time to purchase and install a rebuilt steering rack. Otherwise you'll end up going to the nearest shop and having them purchase and install at your mercy. Heck, you might as well wear a skirt and a t-shirt that reads "RAPE ME" when you walk in.
        Try www.meridianautoparts.com for a good rebuilt rack at a good price..
        • DarkWing6
          • Apr 2004
          • 7144
          Well, I guess that sucks. Sounds like time for a E36 M3 rack, huh? I did use auto tranny fluid, but I'll try to find some with the stop leak in it to hold me over till I can afford a new rack. What is a E36 M3 rack gonna go for?
          • mikeedler
            • 6707
            stop leak isnt going to do crap for a rack that is emptying out in a couple days. It is more than likely the seals that are for the rods that come out under the boot" the accordian looking things. here in germany they sell a seal kit to rebuild the racks. if i remember righ it was only like 20 or 30 dollars. not that hard to repair.
            • DarkWing6
              • Apr 2004
              • 7144
              Have you done this? Does it take any special tools or anything? BMA sells them here for like $50. That seems like a much cheaper weay for me to go.
              • mikeedler
                • 6707
                personally i never did one, I can get a complete rack here for close to nothing from the salvage yards around here. but my friend did his, and he said it was easy-- but I didnt see him do it. it didnt leak either when he was done, and he replaced everything on it.
                  • 34839
                  the problem is the seals aren't the only thing that may need replaced, the rack itself can wear which you can't repair with a seal kit.
                  • mikeedler
                    • 6707
                    understood, but he was talking about a leaking p/steering rack.
                    • arsevader
                      • May 2005
                      • 1025
                      The symptom of a worn rack is a leaking rack. The shafts wear and replacing the seals isn't going to fix this.
                      James
                      • AdamF 88iS
                        • 2051
                        James
                        Exactly, and for this reason the rebuild kits never last too long. I refuse to even do a rebuild on customer cars at work.
                        Adam Fogg- '88 M3
                        • uflnuceng
                          • Apr 2005
                          • 1049
                          I have a used rack I got from BavAuto, has about 4k miles on it. About $120 shipped? PM me if interested.
                          Needs new tie rods, but you could probably reuse yours.
                          • DarkWing6
                            • Apr 2004
                            • 7144
                            I could pull the one from my bros parts car, but I'm thinking of going the new gasket route. I don't want his to leak on me and have to do it again in a couple thousand miles.
                            • 808BMW
                              • 2910
                              Are you sure it's the rack? I've had both the rack AND the high pressure hose go out on my car. The hose was spraying all over my engine, so it was hard to find the leak.
