HVAC Not Working After Radio Install...Help!
  • NickAlero
    • Jul 2011
    • 98
    So I recently did a radio install on my 85 325e and my HVAC does not work. Won't turn on, AC lights won't light up, etc. Nothing.
    Checked the fuse box, no blown fuses. If this affects anything, my speakers on my left side are temperamental and less audible than the right side. I was told by a friend that the speakers may share common ground with parts of the HVAC system, so if that is the only problem that would be amazing. Other than this though, I'm not sure where to go from here.
    Help, anyone?
    Thanks in advance for looking!
  • redsubdivisions
    • Feb 2011
    • 1762
    E30's share a common ground, so it's very likely that is the culprit. Remove the rubber green boot that ties all the grounds from the speakers in, clip off that metal piece of shit, re-wire as necessary.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • NickAlero
      • Jul 2011
      • 98
      So that will solve my speakers cutting in/out or do you mean the hvac is a shared ground?
      • NickAlero
        • Jul 2011
        • 98
        bump need help
        • Kershaw
          • 11822
          you didnt run new speaker cables to all the speakers?
          AWD > RWD
          • redsubdivisions
            • Feb 2011
            • 1762
            you don't need to run new wires. It's better if you do so you can add an amp later on (although I have been reading posts of people making it necessary to do so because of sound quality or something along those lines), but if you want to just wire up a quick radio, you can use the stock wires. I did it in mine with a Sony head unit and speakers and it works pretty well for 22 year old car. Like I said in my previous post....clip off the metal crimp that is covered in the green rubber cap and if you need to know the wires and what they go to, pull the speakers out and look on the back of them for the correct wires. When I did mine, the grounds were all yellow with a brown stripe. BMW has the wires twisted together from the factory, so it's pretty easy to find the ground for each individual speaker. For example, you pull out one of the speakers and it has a yellow wire with a brown stripe (the ground wire for that speaker) and a yellow wire with a red stripe. Look for the factory wires behind the radio (in this case the yellow with brown stripe twisted with the yellow with red stripe), cut, crimp/solder, and then follow the procedure until you are finished.
            As far as your HVAC goes, you will have to check around to make sure you didn't bump something and pop a fuse. Remember to start out simple when it comes to tackling problems.
            • StereoInstaller1
              GAS
              • 22679
              This is incorrect.
              There is no connection AT ALL between the HVAC system and the audio system.
              They are not powered together nor are they grounded together...unless you went totally stupid when you installed the deck.
              Take it apart and take some pictures of your connections.
              EDIT: please tell me you at least read this thread: http://www.r3vlimited.com/board/showthread.php?t=191119
              Closing SOON!
              Thanks for 10 years of fun!
