BLOWING HEAD GASKETS !
  • drcrougeux
    • Mar 2005
    • 13
    Allo.
    Need some solid mech/tech advice.
    I have a 1988 325 ic. In April the head gasket blew and was replaced, including new torq head bolts. Nothing else was needed.
    On Aug 19. The new head gasket blew. WTF !
    WHY ? WASSSUPPP, HERE ?
    PLS ADVISE....
    drcrougeux
  • bmwguru007
    • 561
    You should go over your cooling system. Did you have the head checked while it was off?
    • mikeedler
      • 6707
      your head is probably warped. seen it so many times here in germany. whenever I have replaced M20 headgaskets, I always take the head in and have it shaved.-- or could be a hairline crack too.
        • 34844
        like mike said, your head is probably cracked or warped. don't worry though, it goes much faster the second time around. ;)
        • drcrougeux
          • Mar 2005
          • 13
          NANDO.
          What goes much faster the 2nd time.???
          Do you mean the 2nd gasket will blow sooner ??
          What is the cost (ave) to shave the head ? (i'm in northern cal )
          pls advise.
          drcrougeux
            • 34844
            no, I mean swapping it is easier once you've already done it once.
            • drcrougeux
              • Mar 2005
              • 13
              Now, I understand.
              How much to shave the head ? (ballpark figure
              Are bmw's known for blown head haskets ?
              Is this a common problem for the 325 ic's ?
              two in 5 months is 2 many.......
              conrad
              drcrougeux
              • mikeedler
                • 6707
                if the head is cracked, no shaving of it will help. you need a new head then, if it is just warped, then shaving is the way to go. If you buy a used head, take it to a machine shop have it shaved, and checked for cracks. It costs a little, but so does a set of head bolts, and a new head gasket for a 3rd time.
