Please help with water leak into drivers footwell
  • clydesdale
    • 631
    I have removed the firewall panel and have cleaned out the channel by the exterior windshield vents. But, I still get some water that seems to drip down by the gas pedal. The passenger side is dry. Where should I check for the posssible source?
  • Todd Black 88
    • Oct 2007
    • 3449
    What did you find?
    I just pulled the covers off my car from storage to find the drivers side carpet wet.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • dougie30
      • Apr 2012
      • 1708
      i have the exact same probelm, someone please elaborate
      M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
      • fronton
        • Oct 2009
        • 1262
        leaking water or coolant? If coolant, obviously a leaking heater core or heater valves going to and from the core. The plastic one can crack or the gaskets can rot away. Its a sticky annoying job but easy if your aren't fat.
        • Aleman
          • Mar 2012
          • 1608
          Todd - what did you find? I had my car in the garage for several months, and when I ran it, I got a little coolant down by the gas pedal. I am certain it's not rain water. Did you resolve the issue?
          R135 /// 1990 Alpinweiß II 325is
          └┼┼┘ /// 1993 Black/Black Convertible (sold)
          ..24
          • dnguyen1963
            • Nov 2011
            • 2651
            Take a look at your heater core. I am sure that it is cracked.
            • clydesdale
              • 631
              My car had a crack in the fire wall footwell seam. I ended up fiberglassing it. It is 95% gone.
              • david2991
                • Nov 2011
                • 315
                Same problem. So pissed just discovered it this afternoon after work. WTF
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  My driverside was the same issue, but up high. I re seam sealed it.
                  Passenger side was failed seam sealer where the water goes out from the air intakes into the fenderwell, pooling at the ac grommet and dripping in.
                  Also the heater core gasket at the firewall is........old and leaks in a heavy rain if the car is facing uphill.
                  2010 F650gs twin
