Flywheel Question
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Flywheel Question
    Will the flywheel from an eta work for a 5 speed swap on a 325i? If so, is there a major difference between the eta flywheel and the 325i flywheel?
  • AdamF 88iS
    • 2051
    Re: Flywheel Question
    It will work, yea. The eta flywheel may or may not be a single mass, the I cars used dual mass. Shouldnt make a difference though as far as if it will work.
    The only other difference is that E cars have a pin on the edge of the flywheel for the sensors to pick up. Doesn't make a difference on I cars, but you can't use an I flywheel on and E car because it won't have the pin.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • RobertK
      • Jun 2005
      • 5864
      Is there a performance difference between the two and how can you tell the difference between the two?
      • Brew
        • 3060
        Originally posted by AdamF 88iS
        ... the I cars used dual mass. ...
        You sure about that?
        '91 318is
        • rs4pro3
          • 5808
          pre 85 eta Single mass-Heavy
          ~86 up Dual mass-Super heavy
          325i-lighter
          323i-lightest(Or at least the one I had was lighter then any 325i flywheel I ever had)
          85 325e 2.7 ITB'd stroker
          • RobertK
            • Jun 2005
            • 5864
            That's great.. so I would be better off getting a 325i flywheel and making a frisbee out of the one I pulled out of the 87 325e right?
            • e9nine
              • 1890
              Typo. He meant to say "I" cars used single mass?
              • screamingbmwe30
                • Jan 2005
                • 415
                ely, mitch and i weighed my 320i flywheel against his 323i flywheel. the 320's is .5lb lighter :twisted:
                • rs4pro3
                  • 5808
                  The one I had was either 323i or 320i, I still don't know how I got it. but it was very lightweight and had the same bolt pattern, spacing, and diameter of a 325i flywheel. I sold it to Coldaccord not sure if he ever used it or not.
                  • screamingbmwe30
                    • Jan 2005
                    • 415
                    not knocking ya, just telling you for info! cheers
