alignment after wheel bearing replacement?
  • Drive Old Cars
    • 63
    I am doing my front wheel bearings today and am unsure if i need top get a front wheel alignment when i am done.
    Is it necessary?
    Yerrp Industries
    www.facebook.com/yerrpindustries
    Nope.
    • nomansland92
      • 1657
      The only thing that is adjustable is the toe, unless it was off before, but otherwise it will be fine
      IX being restored here
      Ix turbo build here
      • Drive Old Cars
        • 63
        Cool, thanks.
        The new hub went on without issue, it took about 35 mins
        Yerrp Industries
        • Huff
          • 2488
          Yep. You do not have to re-allign. However, if the bearing was bad for a long time, your tire might wear wrong on the inside and the car could pull to the side until the tire wears back to center.
          Just an FYI
          • E30_fiend
            • Apr 2006
            • 7348
            what he said.
            You MAY have a problem but its very unlikely. Its good to know people will still shoot you straight and let you know ALL the possibilities
            Taylor
            • Van Westervelt
              • 9365
              Alignments are pointless unless all things on the front end are in good shape anyway. Bearings, tierods, control arms, and bushings.
              Just since this is a discussion about needing alignments. Ive ran into a few people lately who have shelled out for them, even with worn out components.
