Black Windshield Washer Reservoir
  • ACHTUNG
    • May 2005
    • 2397
    I looked up the part number of the reservoir in this picture but I only come up with the white translucent reservoirs. Does anyone know what reservoir this is:
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
  • N2MYE30
    • Oct 2007
    • 5536
    I thought it was painted...at least thats was what I was gonna go.
    COTM
    • ACHTUNG
      • May 2005
      • 2397
      oh shit. That makes sense. Can anyone confirm that it's painted?
        • 37832
        Painted for sure, they came white/clear from the factory.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Huff
          • 2488
          %100 positive it's painted..
          • ACHTUNG
            • May 2005
            • 2397
            Thanks. Now I have to figure out the best way to paint plastic without having it chip easily.
            • Huff
              • 2488
              I would either use Fusion (for plastic) Satin Black or some SEM Trim Paint. I've had wonderful results with both if prepped properly.
              That tank does look great in that car...
              • ACHTUNG
                • May 2005
                • 2397
                How do you prep the plastic other than washing it with dawn?
                • N2MYE30
                  • Oct 2007
                  • 5536
                  After wiping it down with IPA, I was just gonna use adhesion promoter then trim paint. I was even going to do the coolant reservoir that way.
                  COTM
                  • LJ851
                    • 7919
                    I think it would look good to leave a vertical stripe clear so you can see the fluid level like on vintage Ducati fuel tanks.
                    Lorin
                    The M30 is God's engine.
                    • ACHTUNG
                      • May 2005
                      • 2397
                      So wipe it down with strong rubbing alcohol then hit it with some Dupli-Color CP199 adhesion promoter then spray it with some Fusion black spray paint. Word.
                      • Huff
                        • 2488
                        Yup.. Clean is the key. I like the stripe in the paint idea. Though, I would spring for a new level (or just one that works) since we have a little light that tells us the business. . .
                        • Cletonius
                          • 2809
                          Don't use paint, it will chip eventually. Use vinyl dye, works awesome on light colored plastics. I used black vinyl dye to turn a beige cdrom drive black for a carputer install and even after 10 years of disc changes no fading or chipping was visible.
                          - Josh
                          1990 325is
                          Need a shift boot?
                          Looking to buy shift boot frames, PM if you have one to sell
                          Here's what happens when you let the internet pick your license plate
                          • ACHTUNG
                            • May 2005
                            • 2397
                            good advice.
