Overhead Check Panel repaired.
  • Ferdinand
    • 205
    I've had a really annoying issue with my tail lights for over a year now. The overhead check panel randomly comes up with a warning telling me that one of my tail lights is burned out, except it's not. There doesn't seem to be any reason for it. The tail lights are working fine.
    It's not even like going over a bump sets it off. I can be sitting idling at a stop and suddenly the check light comes on in my instrument cluster and the overhead check panel shows a "REAR LIGHTS" warning. It doesn't do it every day. Sometimes a whole week goes by and I think it's cured itself, but then it starts doing it again. Grrrrrrrr.
    I've tried replacing the tail light bulbs, no difference. I've taken the tail light clusters all apart, cleaned up all the contacts, no difference. I even uninstalled and opened up the check relay box (mounted under the radio antenna). There's nothing wrong with it. It works perfectly.
    I studied the wiring diagram. Power to either tail light bulb flows through the check relay closing two relay switches (one for each tail light bulb). As long as both tail light bulbs are receiving power and the filaments provide a path to ground, then both relay switches remain closed. When either or both bulbs burn out, then one or both of those relay switches open interrupting the ground path from the fault indicator, which triggers the warning light in the overhead check panel.
    Studying that diagram again yesterday I finally had a clue! That ground connection to the fault indicator on the overhead check panel is via Pin-13 of the 26-pin connector (two rows of 13 pins). That means it's one of the outermost corner pins. If those large connectors aren't pushed on or pulled off straight, it's the end pins that see the highest bending stresses. Gee, I wonder...
    So, it was time to have a closer look at the check panel itself.
    With the box opened up, the circuit board can be lifted out. Flipped over, it looks like this. Pin-13 is at the bottom-left corner of the socket for the 26-pin connector visible here.
    Check it out! There's the problem right there. The solder joint has a hairline crack around that pin.
    Eureka!!! Whipped out the soldering-iron, reflowed that solder joint, and hallelujiah, I think it's fixed now!
    The warning light hasn't come on again since then. Of course this might just be one of those weeks where it has mysteriously and temporarily fixed itself...
  • Ferdinand
    • 205
    While I was in there, I fixed a second problem with the overhead check panel.
    The other day I was driving along and suddenly the CHECK light started flashing again in my instrument cluster.
    I suspected the usual recurring false alarm about the tail lights, so I looked up to the overhead check panel to see which warning LED is lit. Except, how bizarre, none of the LEDs are lit in the display!? Huh? That's not right.
    When I pushed the "CHECK" button, all of the LEDs lit up, as they should with that test function, except the LED for the ENGINE OIL warning which stayed dark. Oh-oh.
    Sure enough, I checked the dipstick and the engine oil level is down to the halfway mark, which normally triggers the ENGINE OIL level warning light in the overhead check panel. But now it seems the LED for that warning light has died. That sucks, since it's actually one of the more critical and useful warning lights.
    So, while I had the check panel circuit board out anyway for my intermittent tail light warning issue, I had a closer look at the pins for the Oil Level Warning LED and discovered another bad solder joint.
    What the heck would cause this to happen? That pin is just sitting loose in a hole??
    I can understand how the solder joints can crack at the pins for the electrical connector, as they are subjected to stress whenever the connector is roughly handled. But what causes a solder joint on an LED to fail like this?
    With the LED pins soldered back into place, the warning light works dandy fine again. And thankfully the intermittent tail light warning seems to have gone away too. :up:
    • Bearmw
      • 1323
      Useful info...thanks
