Fuel Injector Questions
  • aaron_silva
    • 1785
    I am replacing the o-rings on my injectors (17.5 #/hr) from an M50. I have 2 questions:
    1) Should the green "cap" slide of to replace the o-ring nearest the yellow whasher? If not, what is the easiest way to replace the o-ring?
    2) If some of the cap have been damaged, is the injector bad? I dont see how it would effect performance. See crappy pic below:
    Are there replacement tips?
    Thanks
    Aaron
    • 34839
    get replacement caps, they are extremely cheap. new caps and o-rings will be around $10, I got mine at napa.
    • arsevader
      • May 2005
      • 1025
      How do you remove the old caps? Just pry them off? Mine are all shot to hell.
      James
        • 34839
        yeah, my old ones just broke apart. might be a good idea to get the new ones first though, just bring in one of the inejctors so they can match it with the proper caps.
        • aaron_silva
          • 1785
          Thanks for the info.
          Aaron
