indicator switch problems
  • Broom Broom
    • Jul 2011
    • 286
    hi,
    my indicator switch has been replaced recently with a used one,
    the indicator works every now and then (makes ticking noise at correct intervals)
    or it either
    ticks like crazy (really fast intervals)
    the bulb has been replaced and this still happens
    its the front left indicator on my e30 that isnt working all other indicators on both sides work fine
    could it be a problem with the indicator relay? or maybe the contacts in the front left indicator?
    if anybody can help me out, would be really appreciated
    - 1987 325e m20 6cyl manual -
    A nfast tick from a turn signal activation means that one of the bulbs on that side of the car isn't working.
    • vpilarrt
      • Jun 2006
      • 2096
      If other turn signal work correctly its not the relay. I would suspect either the contacts for the light or a wire is intermittently open or grounding.
      • Broom Broom
        • Jul 2011
        • 286
        thanks for your help, ill pull out the indicator housing and have a look
