Another high idle thread
  • mcruz121
    • 288
    I idle at 1000 rpm but when I turn my A/C on my idle drops down to
    500-600. Has anyone experienced this?
    And yes I tried searching but was not able to find someone with the same problem.
  • mcruz121
    • 288
    Can anyone help me out?
    • bmwm42
      • 6300
      Lets start by getting more info about your car savy?
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • 801coppertop
        • 293
        I have the same problem... I think it is a intake leak on mine but I am interested to see the other possibilities that people come up with.
        • june3o
          • Apr 2011
          • 90
          ugh make that 3! Just happened recently.. just out of nowhere my car would idle at 1k rpm.. couldn't be vacuum leak..I replaced all possible vacuum hoses.. maybe I missed a couple I don't know... or something else?
          • bmwm42
            • 6300
            Possiblities icv tps sensor afm maf vac leaks oxy sensor car staying in open loop timing off bad accelorator cable cold start injector etc etc
            • mcruz121
              • 288
              Thanks for the help guys. I'll check out the TPS in the Bentley
              • clydesdale
                • 631
                I have been plagued by something similar. When I hit the a/c button, the car wants to idle at 2k. I have replaced the intake boot, icv and some vacuum hoses. But, still no luck.
                • BergerNJ
                  • Oct 2009
                  • 349
                  rarely my m20 will idle high around 900-1k and eventually settle......funny thing is when I hit my a/c button the idle goes maybe 100 rpms higher but the engine sounds under heavier load. It doesn't rev noticeably higher at all, just heavier sounding like its under load.
                  • mcruz121
                    • 288
                    anyone else with this problem?
                    • mammoth_e30
                      • Nov 2009
                      • 818
                      x2, started today
                      • long tall eta
                        • Jul 2010
                        • 1536
                        my eta was having a random intermitint stall thing when warn, usually after shutting her down and restarting a couple times, like running your weekly erands but only in the sumer, never ever in the colder months hmmmm. replaced with used but from known working cars, the fpr, tb and tps, icv, air flow box. put on new tb boot, and the hose from the vc to the tb. did all this the same day and guess what, thats right, stall problem gone but high idle. now this is where it gets weird. if the ambiant air temp is over 60f she idles at 1000. if the outside temp drops below 60, the idle shoots up to 1250 or 1300. now, from time to time at the higher idle if you let the clutch out to drag down the rpm's, she will drop to 1000 and stay there. would an intake leak be ambiant air temp sensitive?
                        • Oolop
                          • 121
                          x...4? lol
                          i have the same prob, i feel like it'd be the tps or maybe a coolant sensor?.... i have an 87 eta and it only idle's weird/high at optimum temp. like from cold, warming up to optimum, it idles fine. but then as soon as the needle's in the middle, it idles high and sometimes fluctuates.
                          has anyone solved their prob yet or have the same symptoms as me?
                          E30 LS1 swap, Tremec TKO, three link live axle rear suspension.
                            Originally posted by Oolop
                            x...4? lol
                            Have the intake smoke tested and fix the leaks the test finds.
                            • MikeDE
                              • 1873
                              I saw the other day by chance that (2) of (3) tabs/receptacles in the TPS conector on the harness were pushed in. The were making no contact to the sensor, hence no communication to the DME. I fixed them and the idle evened right out.
                              -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
