I have a water leak, behind the fuse box. I finally tracked it down. The seam is rotted and water runs right in. To patch it right, I need to remove the fuse box and make room.
Anybody know the procedure or have a write up to remove the fuse box? water leak.
Tags: None
Bumped because I have a similar problem and was searching for an answer... I don't think I need to remove the whole thing - but I need to remove enough wiring to get it out of the way. -
FYI I ended up just popping the wire loom clips off the inside of the fender and unbolting the loom from the firewall to give me some room to lift up the box.Comment
