m20 wont start!!! CPS, battery, and COIL check out fine...
    hey guys,
    so yesterday, i go out to try and start the car, and the bitch doesnt want to start!! i tested the crank position sensor with a ohmmeter, as well as the battery and the coil, and each part tested turned out NOT faulty...
    the car will crank, but NOT start...im lost...
    any help would be appreciated...:hitler:
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
    i just did mine its really simple. First of all buy a Bentley manual and that will solve most of your problems.
    But the connector is under the diagnostics plug and the wire runs by the w/p and the fan so make you to secure the wire good and the cps is right on the harmonic balancer on the passenger side. I believe its like a 5mm allen key or something like that
    hope that helps, and you can test yours by doing a ohms reading on two of the pins and it should read like 500 to 600 hundred or something close to there
    IX being restored here
    Ix turbo build here
      im sorry, but huh?? I have a bentley, and ive searched for the "crank position sensor" but i cant find a damn thing within the manual..ill safely assume its named something else in the manual...if so, whats a different name the CPS would go by?
        DUde it is super easy to do. If you can find the crank pulley and the toothed wheel you can replace it.
        Argh cant find my book I was going to give you that page #
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          lol so im getting alot of different info here...ill check the location and report back in!
            dont have a diy but here is a picture of where its located...its the wire in the middle of the picture leading to the little cylindrical metal piece. picture is part of the timing belt diy, might help you a bit.
              awesome, perfect timing!
              i actually found it in my bentley (which they called the "pulse sensor")...
              i was examining the 5mm hex nut that holds the sensor in place, and that damn thing is stripped...
              any thoughts on how i can remove it??
                Not to say your buddies are wrong but have you checked the resistance of the sensor before replacing it?
                Do have a 5.5mm allen or a standard size to maybe fit in the screw?
                COTM
                  yeah, im definitely not forking over money before testing it out!
                  and i literally just bought some tools, so im gonna get to work.
                    If the allen head in screw is stripped, you can get it out with vice grips. The only tricky parts of replacing the crank position sensor is that you need to set the air gap to 0.040" +/- 0.05" and that the clips on the plastic wire chase will probably break. A new chase and clips should be on hand before pulling the old sensor. Well that and that you'll want to remove the fan and water pump pulley to get to the wire chase.
                      It should ohm in the low to mid 500's. I have had one check out fine that I swear was still bad. Replaced it with a brand new one and it fired right up. Unfortunatley I replace a couple other things as well so there is no real way to know what the culprit truely was.
                      Originally posted by Roysneon
                      $5 shipped?
                      Originally posted by MarkD
                      You are a strange dude, I'n not answering any more posts from you.
                        Check the resistance across pins 47 & 48 of the DME connector, which should be 500-560 ohms. If
                        the CPS is dismounted, the resistance can be seen to change from about 500 to
                        540-560 ohms when a ferrous object is brought to the face of the
                        sensor. Neither pin should be grounded.
                          well, i checked the CPS resistance, and it was reading a solid 532-535 ohms every test...
                            Then its probably not the CPS.
                            COTM
                              yup, i realized that...i checked the coil and battery too...still no go.
