anyone recognize this bolt
  • jrobie79
    • Mar 2006
    • 2525
    so I'm finally in the process of putting everything together fro my major overhaul and I have this bolt I can't figure out where it goes. I think only one of them is used, but I can tbe certain, I had another e30 that the other one must have come off if only one is used.
    measures:
    m12 size x 1.5 thread pitch about 3.75 inches long - 19mm socket for both head and nut
    1991 318is m42.
    anyone shed some light?
    1991 318i ---- 308K - retired
  • jrobie79
    • Mar 2006
    • 2525
    was thinking it might be the rear trailing arm bolts/nuts, b/c i put on the weld on plates...sound right?
    • EThirty318i
      • Dec 2010
      • 219
      do you know what size?? if its a 17mm and you have more I'd say its the bolts at the out-put flange to the guibo/ D-S... if not and you only have two I'd adgree w/ jrobie79 and say trailing arm bolts
      • browntown
        • Jun 2004
        • 3524
        Kind of look like the bolts that hold on the ps and ac brackets, but I don't know what you've been wrenching on.
        • Nick325is
          • 1409
          Thats my guess as well.
          • jrobie79
            • Mar 2006
            • 2525
            i havent taken the PS or AC pumps/compressors off, I was doing a clutch job and complete rear suspension/hard brake line/diff refurb, also welded some patches in the floor, and changed upper and lower oil pan gaskets, changed the oil filter housing gasket/oring...nothing major engine related
            • StereoInstaller1
              GAS
              • 22679
              those are radio bolts
              Closing SOON!
              Thanks for 10 years of fun!
              • lbreevesii
                • Aug 2009
                • 412
                ^ lul
                I'm guessing trailing arm as well. If I can remember to i'll measure one for ya.
                I don't always wreck cars, but when I do I wreck them into trees.
                91' 318is S50 swap - The Black Widow
                • barry
                  • 1642
                  If it's 15mm they could be for the steering rack
                  GL
                  Barry
                  • jrobie79
                    • Mar 2006
                    • 2525
                    its not 15mm, I havent done any work on the steering rack -- the measurements are 19mm, its a m12 x 1.5 thread pitch
                    • jrobie79
                      • Mar 2006
                      • 2525
                      confirmed, trailing arm mounting bolts
