Best gasket kit for M42 rebuild?
  • bflan2001
    • Sep 2007
    • 65
    I've been searching many different sites and have found many 'kits' available, but none of them list exactly what's included. I want to replace pretty much every gasket I can before I put this motor into my car. Any suggestions?
    edit: these are the two best kits i've found, but it says in the description they may not contain all the gaskets listed.
    http://www.rockauto.com/catalog/moreinfo.php?pk=1021026
    http://www.rockauto.com/catalog/moreinfo.php?pk=1399993
  • Ryann
    • 3350
    The Victor Reinz sets are superior to the Fel-Pro imo.
    • bmwm42
      • 6300
      victor reinz but i prefer elring or goetz
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • bflan2001
        • Sep 2007
        • 65
        that's surprising to hear..i'm from the e21 world and the victor reinz head gasket is thought of as garbage by m10 guys.
        where can i find the elring or goetz kits?
        • Ian Bowers
          • Apr 2008
          • 1120
          A few people have had shitty experiences with reinz parts. I know I used them when I replaced the gaskets on my M42, and they are leaking. I also think Buttchug said something about them leaking in his M42 build thread.
          Can't help with a kit, I ordered gaskets through pelican cross-checking with the part #s from realoem.
          • bmwm42
            • 6300
            get em thru blunt or bma or levent goetz or the elring ones are the ones i have used no leaks to speak of
            • Ryann
              • 3350
              While it may not be up to the heavily boosted task, the VR m42 head gasket is a high quality piece. Paper gaskets should always be substituted with Right Stuff or equal to avoid leaks, particularly in Al to Fe situations imo.
              • Dj Buttchug
                • Jun 2010
                • 7683
                This^
                VR sucks!!! I had to re-do my head gasket on my new engine because Vr gaskets started leaking both oil and coolant between the head and block. It wasnt because im a shitty mechanic or i didnt prep either. The shit was immaculate. fail. will never buy Vr gaskets again.
                goetz all the way
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • bflan2001
                  • Sep 2007
                  • 65
                  i usually order through pelican and i've thought about taking the time to order each gasket individually, but i figured it would be way more expensive than the kits. the only kits i can find so far are either fel-pro or victor reinz. i'll keep searching for a goetz kit.
                  • Dj Buttchug
                    • Jun 2010
                    • 7683
                    fwiw i really only had problems with the headgasket itself. smaller gaskets like timing case h2o pump housing ect ect i had no problems with. i recall having issues with upper oil pan gaskets and the headgasket.
                    best of luck
                    Ig:ryno_pzk
                    • immajackuup
                      • Dec 2010
                      • 1132
                      What about Elring Klinger and Corteco-CFW??^^^^^ They are oem suppliers.
                      • Ryann
                        • 3350
                        Funny Chuggz, 'cause my VR set has been 100% tits for a year and counting! :D Not saying VR's the end-all-be-all, but definitely superior to Fel-Pro in my experience.
