I know it sounds stupid (M10), but a friend of mine said he could make it run. He loves 2002's and even has a tatoo of one on his arm. He claimed he could get rid of all of the electronic stuff and put two weber carbs on it like his 2002 engine. I trust him because he has had his shop for ten years now. Anybody ever tried this before? Thanks
M10 Help?
When I got my 85 318i it barely ran. The fuel system was full of rust, so instead of replacing all of the injection components I found a 2 barrel downdraft manifold and a weber 38/38 dgv carb. It is a very very simple setup. just remove the fuel injection pump and install one for a carburetor. use the same wires that go to the injection pump. the rest is simple bolt on you may not even have to change the throttle cable (I didnt). In then end I had a Lynx manifold with a mikuni 44 PHH which was a badass setup for an m10. The dual weber setup will be even better but gas milage will decrease.
If your friend knows as much as you say he does then let him do it you will love that setup on an m10. If i could get my hands on a triple sidedraft setup for my m20 I would run carbs on it too.
StevenComment
go for it double Weber 45 DCOE is your way,
I had a stock carbed M10 (Pierburg 2BE) and that was either shit
1989 E30 318iS
_______________________________1989 E30 325iC M-Technic I
1997 E36 328iT
1990 E30 325iT 24v SOLD
1989 E30 325i 2.7i M-Technic II SOLDComment
