Engine bay fuel pump install
  • DaveSmed
    • Apr 2007
    • 1407
    Anybody come up with a clean way to install something like an 044 in the engine bay and wire it up?
    Looking for inspiration on mine, was thinking on adding a relay into K9 in the fusebox and use Fuse 26 as far as wiring.
    Mounting the bugger cleanly and plumbing it so it looks nice looks difficult too. Hmm. Frame rail? Fender liner? AFM bracket would be unsightly.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
  • wodcutr
    • Apr 2009
    • 2193
    I had a car that had a fuel pump mounted in the engine compartment and it would not pass safety inspection. I would advise against doing this!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
      • 37833
      Why would you need to do this?
      Grover Beach, California
      BimmerHeads.com
      • DaveSmed
        • Apr 2007
        • 1407
        My fuel pressure regulator is 5 bar, so I went with the 044. I'm putting it in the engine bay and using the stock pump as a lift pump so that the majority of the fuel system is low pressure, and only a short section under the hood to the engine runs at the high pressure.
        Figure that will be a lot gentler on the 20yr old fuel system than asking it to go 2 bar above what it was designed for in the first place.
        -Dave
          • 34844
          I'm going to be using the same pump, but my plan is to put it where the early second pump used to be, and use my brand new in-tank pump as a transfer pump. And of course replace everything original in the fuel system..
          since you must be doing something similar, how does that 5 bar FPR reference manifold pressure? or does it?
          actually mounting it neatly under the frame rail on the drivers side seems like a decent idea. easy to get to, as well.. hrm.
          • E30_fiend
            • Apr 2006
            • 7348
            This^^^
            Mounting it in that area will allow for your setup to work well but wont cause any problems later like ref or safety inspection. It will still supply ample pressure to the system but wont be shoved somewhere in the engine bay. If you dont take this advice, at least put it somewhere that will be safe and out of sight.
            Taylor
              • 34844
              where is it mounted on the E46?
              stupid hybrid returnless fuel systems.. screw the EPA!
              • Hellabad
                • 807
                If you mount it in the engine compartment, it will be like having tinnitis.
                It will drive you crazy.
                It is bit expensive, but not THAT bad, to just run one whole new braided line from new pump in secure stock location to FPR.
                Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                Ground Control Gallery
                The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • 34844
                  how loud is the 044? I'm assuming it's not wisper quiet to be able to flow all that fuel at high pressure..
                  • TG Goose
                    • Jul 2011
                    • 234
                    I mounted a high pressure inline pump in my engine bay in my Camaro, even with heat shielding the underhood temps could sometimes get so high, that if I turned off the car (and pump) I would cause a vapour lock in the pump and it wouldnt start until it cooled down (usually 20min or 5min with a bag of ice sitting on top of it!)
                    ______________________________________
                    1984 LSB 318i - Sold
                    1986 325i - Motor Swapped Track Car Project
                    1995 318ti - Sold
                    1999 540iA - Daily Driver
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      I'm not TOO concerned about heat or inspection, Heat wise, I'm looking at the drivers side, away from the headers. PA will be fine with it as long as it's done properly. Hell the green beast in the sig has a fuel pump bolted to the engine....
                      nando, I have the old ancient dinosaur, the S50B32. Mine is referenced to the vacuum rail that the brake booster line is attached to, and it connects in between #5 and #6.
                      Hopefully if I can put that thing on something solid enough it won't be too noisy, thats part of why I didn't want it under the cab. I have it connected and ziptied to the drivers framerail now for getting the engine running, and it's not TOO bad, but I know if it has a panel to amplify itself with it could get annoying.
                      I'm gonna have to crawl under there and take a look, actually attaching the thing to the car is puzzling too, its a round tube. I have some conduit brackets that I think might work....
                      -Dave
                        • 34844
                        There are billet mounts on ebay for $35, no idea of the quality.
                        anyone happen to know what size the s54 injectors are rated at running 5 bar?
