clutch pedal height ** NOW WITH PICTURE**
  • jrobie79
    • Mar 2006
    • 2521
    I recently replaced my clutch, master and slave cylinder, and when I hooked everything up, my clutch pedal now sits about 3 inches higher than my brake pedal/where it sat before. I did bleed the system and there is resistance when pressing the clutch, although it doesnt appear to make shifting any easier with the pedal pressed down (car doesnt start yet; redoing some vacuum lines, intake manifold/valve cover painting, other problems I'm fixing).
    I did not change anything with the pedal mount, only the cylinders, I did add a stainless line from the hardline to the slave cylinder.
    Could this be a problem with an incorrect master and or/slave? [Maybe slave cylinder since the effort required to shift gears seems about the same clutch in or out.] I bought the master off craigslist, it looked identical to my old one, and I bought the slave from BMA so I'm assuming it is the correct one.
    Any ideas?
    1991 318i ---- 308K - retired
    The rest position of the pedal can be adjusted via the eccentric bolt at the pedal arm pivot point.
    • jrobie79
      • Mar 2006
      • 2521
      was that one of the bolts required to take out to replace the master cylinder? If so then maybe that would work, but I only took out the master cylinder and replaced it, nothing else.
      • Jean
        • 18228
        3 inches?!
        • jrobie79
          • Mar 2006
          • 2521
          yeah it sits pretty damn high, it does go all the way to the floor, im wondering if the master is the wrong part and made for another bmw
          • DRTSRFR
            • May 2008
            • 1836
            What's the part number?
            Suspension tips here...
            http://www.r3vlimited.com/board/album.php?albumid=757
            • accident
              • 7303
              pictures
              Moral of this story?
              • jrobie79
                • Mar 2006
                • 2521
                so i took the master cylinder out b/c it didnt look the same as the one in my sisters. the one on her car does not have that brass part as seen in the pic:
                just looking for confirmation that this is in fact the wrong part (although the numbers on the side are the same: S5459A)
                • nomansland92
                  • 1657
                  Looks like the right master cylinder to me. Unless I put the the wrong one in my car
                  IX being restored here
                  Ix turbo build here
                  • accident
                    • 7303
                    Brass part? I don't see anything brass in that picture.
                    • glucklich21
                      • 1912
                      That one is too long because of that "brass" (it's zinc coated steel) bit.
                      See how my old one lacks that part? That's not an E30 MC.
                      • jrobie79
                        • Mar 2006
                        • 2521
                        thanks guys, looked at my sisters and noticed the same thing, that steel part at the end wasnt there so I ordered a new one from BMA....wish i saved the email from the guy on craigslist who sold it to me
