wierd clunking when clutching
  • crazys
    • Jun 2005
    • 38
    Whe I clutch out of first and sometimes second there is a clunking/shuttering sound anmountsd vibrations I thought it was the tranny mount so I swapped the tranny and engine. and its tsill there I do not think its the CSB because it only happens when clutching wiggled the drive shaft around and it felt normal.
    __________________
    back harder then ever
  • Digitalwave
    is a poseur
    • 6293
    What do you mean by clutching? As it it happens when you have the clutch in and you are changing gears?
    RISING EDGE
    • bimmer8604
      • 3017
      if its rattling/clunking with the clutch out, then when you put the clutch in andit stops, then it could be some crankshaft end play. could probably also be your throwout bearing or something.
      a better description would be helpful
      kyle
      1988 M3, 97 840, 99 XJ
      DILLIGAF
