My excel file for speed based on gear ratios
  • shiboujin
    • Feb 2006
    • 2791
    I made an excel file that takes gear ratios, final drive ratios and tire size to calculate what speed you are at a given rpm.
    File:
    http://slidewaysonline.com/files/E30...r%20ratios.zip
    My tire diameter is bigger than stock. I think stock is like 23.2. You can get the diameter by plugging your tire size into the miata tire calculator (http://www.miata.net/garage/tirecalc.html).
    When the excel file loads, GR260 ratios are on the left, ZF are on the right. If you want other transmissions, go here: http://e30performance.info/viewtopic...&t=941&p=28445
  • AndrewBird
    The Mad Scientist
    • 11898
    Nice work. I made something similar, but a bit less complicated:
    The numbers that are in it are for an MGB, but you can change all the parameters. It also tells you what percentage your speedo is off like the Miata calculator.
    • Click
      • 637
      I use a slightly modified diffs online spreadsheet....
      ส็็็็็็็็็็็็็็็็็็็็็็็็็
      I need you to exfoliate my ballsack
      Build Thread?
        • 34844
        why not share the file? :)
        -just a nit pick, but the ix uses a planetary gear to split torque, not the VC. the VC is a slip limiting device (there are AWD systems that use a VC to split torque, and they suck).
        • shiboujin
          • Feb 2006
          • 2791
          lol so many ppl just want to upstage me. My file is just plain and simple. I put a graph on it though. :)
          • Click
            • 637
            Updated
            Download
            Build Thread?
            • lbreevesii
              • Aug 2009
              • 412
              here is a web based calculator a friend put together for one of his fiero sites. If someone wants to host it he has said he is more than happy to make a BMW transmission specific version.
              This is the official website for the Georgia Fiero Club. We specialize in helping other people with Fieros, organizing Fiero-related events, etc.
              I don't always wreck cars, but when I do I wreck them into trees.
              91' 318is S50 swap - The Black Widow
