convertible drain holes
  • Trptguy
    • Aug 2007
    • 799
    I am getting a ton of water on my drivers side floor. I am wondering if the rocker panel drain holes are plugged up. Of course being an idiot I can;t seem to findt hem. Does anyone have a picture of the location?
  • Trptguy
    • Aug 2007
    • 799
    no one????????
    • Bearmw
      • 1323
      Could be leaking through the hvac assembly gasket. Pour water in the cowl area and see if it drips down by the heater.
      • Ceeker
        • Sep 2009
        • 2821
        there is one drain hole on the passenger side of the fire wall on all e30s. there is a plastic vertical down spout exiting the firewall. if that is plugged water will back up into the hvac and work it's way back into either the passenger or drivers side floor. remove the plastic vent below the windshield. and remove the plastic spout and clear out the debris.
        • Trptguy
          • Aug 2007
          • 799
          already cleared that elephant spout...so that isn't the issue.
          it seems to be coming from underneath the carpet and is not dripping. How can I check to make sure HVAC assemble is watertight?
          Thanks!!
          • cabriodster87
            • Jan 2011
            • 1042
            Also check for rust inside wheel well at the top, just under where the fender meets at the window pillar.
            Reich und Roll!
            • Bearmw
              • 1323
              lift up all the carpeting in the footwell area. Have someone use a hose and spray a lot of water in the cowl and also in the wheel well, and even firewall area (while avoiding soaking circuits and connectors). While the person is applying water, carefully inspect all around the HVAC and pedal area with a good light. That should show where it leaks from.
              • Trptguy
                • Aug 2007
                • 799
                yrah guess i will have to do this....one more thing le sigh
                • Bearmw
                  • 1323
                  Yeah...old cars suck sometimes.
                  • Trptguy
                    • Aug 2007
                    • 799
                    ok its not the cowl leaking....dammit.
                    i have about an inch of water in the car now from last nights rain. i am thinking the drivers side rocker panel drains are plugged and not draining, but i can;t find them??
                    • beybedba
                      • 517
                      are yo sure it's water? and not brake fluid from a master clutch cylinder leak?
                      • Trptguy
                        • Aug 2007
                        • 799
                        positive
                        • Tico Frank
                          • Feb 2011
                          • 351
                          Where did the water come from?
