What's draining my battery?
  • herbivor
    • Apr 2009
    • 1420
    New battery,
    Newish alternator,
    If I leave my car sitting for more than 4 to 5 days, it is completely dead when I go to crank it. It needs a jump. The only thing I can figure is the short I know I have somewhere in my wiring that leads to the rear defrost switch. I've been procrastinating fixing it because I hardly use it. Could that be draining the battery? Other than that I can't imagine my analog clock would be sucking that much juice while it sits.
  • reelizmpro
    • 9558
    Fix the short for sure. Do you leave an ipod plugged in charging? alarm? all the little things add up.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • cabriodster87
      • Jan 2011
      • 1042
      If you disconnect bat - and jump clamp to post with DVOM on highest amp setting, check to see if there is excessive draw. Then pull fuses one at a time to isolate the offending circuit. Here is a detailed explanation.
      Car batteries don’t live forever. Here’s what to do when one meets its maker.
      Reich und Roll!
