right part? / process to swap door connector
  • jrobie79
    • Mar 2006
    • 2526
    First, is part #15 the correct part for the body side of the door connector?
    Second, how hard is it to put this new piece in? Just take the pins out of the old one and pop them into the corresponding slot in the new one?
    1991 318i ---- 308K - retired
  • jrobie79
    • Mar 2006
    • 2526
    double post, delete
    • dogsbark26
      • Nov 2008
      • 533
      Hmmm. Yes but "just" taking the pins out requires purchase or construction of a tool to depress the barbed pin for removal.
      • jrobie79
        • Mar 2006
        • 2526
        Yeah I figured it would be a special tool to do that, I also have another 318 at my disposal for reference, any idea what that tool is called?
        • dogsbark26
          • Nov 2008
          • 533
          Nope. If I recall correctly, I made one out of an old metal ball-point pen refill. Or maybe I bought a piece of brass tubing from the hardware... Still not simple though.
          • glucklich21
            • 1912
            Radioshack has a pin extractor for $6. I used that to change over some pins on mine.
            BTW you have to take apart the connector before you try removing any of the pins.
            • jrobie79
              • Mar 2006
              • 2526
              Yeah, i dont think I'm going to have to remove any pins, I just need that outer sleeve of that connector with those little lock tabs to secure it to the door jamb, being old and brittle I cracked a few so now I have to jiggle it to get my window to roll down.
