[B]ok, after rebuilding the head I put everything back as it is supposed to be unless I reversed something. threw a charged battery in and the car cranks but no start. Not even an attempt at starting..
I have not changed anything on the car pertaining to relays etc. I also didn't disturb anything in that manner. Grounds are hooked up. I don't see any fuses blown.
What I've checked for far:
Power to car - ground fixed
Power to coil - tested with multimeter
Fuel delivery is good - changed relay to be certain - smell raw fuel in the in throttle body.
Swapped dme
swapped CPS
all fuses checked out fine
new rotor, cap, wires.
Switched the CPS and coil pickup numerous times.
I STILL HAVE NO SPARK!
Swapped dme
swapped CPS
