Want to remove surface rust on caliper
  • uflnuceng
    • Apr 2005
    • 1049
    Anyone have insite on this. I have a good amount of surface rust no the calipers and would like to clean them off before I paint them with VHT caliper paint. Should I be bothered... I would think leaving the rust would make the paint job look textured... maybe I'm wrong.
    Thanks
    Jared
  • asubimmer
    • 6482
    sand blast em
    • uflnuceng
      • Apr 2005
      • 1049
      Don't have a sand blaster... sounds expensive...
      • arsevader
        • May 2005
        • 1025
        Re: Want to remove surface rust on caliper
        Thanks
        Jared
        Just clean them well with a wire brush and brake cleaner. The surface is texured anyways from the cast metal. The rust is just a surface coat.
        They'll look fine.
        James
        • uflnuceng
          • Apr 2005
          • 1049
          Words of wisdom from Leonard Nemoy... thanks :D
          • arsevader
            • May 2005
            • 1025
            "In the middle of the earth in the land of shire lives a brave little hobbit that we all admire with his long wooden pipe, fuzzy wooly toes....."
            • asubimmer
              • 6482
              if you have a air compressor you can buy a hand held sand blaster. They don't work quite as well though.
              • rs4pro3
                • 5808
                I used a small media blaster from Harbor freight it was around $30, just have to hook it up to a Air compressor, it worked realy good for cleaning up the calipers for my car.
                85 325e 2.7 ITB'd stroker
                • AdamF 88iS
                  • 2051
                  Another vote for wire brush and brake cleaner.
                  If you can find a wholesale detailing supplies place, you can get some acid used for cleaning chrome wheels (usually some mixture of hydrofluoric acid and hydrochloric acid), that will work well too.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
                  • cthulu703
                    • Oct 2004
                    • 288
                    They sell that mag cleaning acid at Baxter's as well. I almost bought some. but HF is the first ingredient on the label and that shit is scarey.
                    • uflnuceng
                      • Apr 2005
                      • 1049
                      I'm just going to go at it with my trusty metal brush. Picked up some VHT Cast Aluminum Brake/Drum/Caliper paint... this shit is going to look good 8)
                      • george graves
                        • 20003
                        Navel Rust Jelly...Havn't used it on rotors - but worked decently on my m30 block that had some rust on the exhaust side of the block. Keep the stuff avay from alunimum though.
                        And it might take longer then what the time on the bottle says.
                        Originally posted by Matt-B
