Which heater core?!?
  • aTron12
    • Nov 2009
    • 98
    I'm starting to smell coolant in my heat and the heater valve has already been replaced which leads to the heater core starting to die a slow death. I want to do this repair with part in hand so I am going to order it in advance. Only catch is that there are two different types to choose from. One is a plastic inlet and the other is aluminum. The attachments also look different.
    Any idea what I should order for my 325is built in 12/88?
    Also it is recommended to replace the radiator cap. Why? Is it because the system is more pressurized... and most likely this cap is 20+ years old and might not hold a good enough seal?
    http://www.partsgeek.com/catalog/198...ater_core.html
    Thanks,
    Adam
    The part you want should be 64118391363
    • aTron12
      • Nov 2009
      • 98
      Thanks!
      • reelizmpro
        • 9558
        You want that first Behr heater core unless you have a euro car without factory AC.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
