I got in my car to leave class today when at like 3-5mph, i hear a loud banging/knocking under my handbrake handle. It only occurs when I start accelerating and stops after about 10mph. From what I read, this isn't a symptom of a bad guibo, but who knows. What do you guys think?
I think my guibo needs to be replaced.
Tags: None
That is usually the symptom of a failed center support bearing mount. In almost all cases that failure is the result of binding u-joints in the drive shaft. Replacing the CSB will result in temporary relief, but the new part will have a short life until the drive shaft is replaced.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
